7-Bedrock
Distributed batch fails
Hi All,
I'm facing a very annoying issue I can't get solved. In Creo 3.0 this program helped me a lot by creating hundreds of PDF files for me. Now since I'm on Creo 4.0 - M110 I'm trying to do the same but it keeps failing after the second object. The first 2 object are running as usual but then it hangs for about 15minutes and fails the rest of the objects.
In the log file the following error is showed but I don't know what to do with it. "Connected to Creo Pro | Failed | [-1] Error: General problem during data conversion."
Thanks in advance for the help!
@BartL wrote:
Hi All,
please report the problem to PTC Support.
Mahesh_Sharma
22-Sapphire I
@BartL
Try the same without using any of the config files.
Mahesh_Sharma
22-Sapphire I
@BartL
Did you get a chance to test this without configs?
BartL7-BedrockAuthor
7-Bedrock
Hi Mahesh,
My apologies for the delayed answer, for some reason I couldn't login last week.
Regarding your question, yes I tried your suggestion but it didn't help. For me the most confusing is that the first 2 items are running as supposed before the batchrun stalls.
Best regards,
Bart
