DLS used confirmation message in Autodesk Vault Add-In for Creo
This Please confirm message comes up when download selected from the Vault Browser.  We would like this message to not appear at all.
We are using Creo 7.0.4.0 and Autodesk Vault Pro 2022 with the 2022 Vault Add-In for Creo.
StephenW
StephenWAnswer
If this is an error generated by Autodesk Vault, you will likely have to get help from Autodesk
I can't see how it would be a Creo issue.
StephenW
StephenW23-Emerald IIIAnswer
Check the download settings for the AutoDesk Vault to see if the message can be disabled.
Creo is not generating that message, the vault software is.
