Does anyone have a mapkey to close all windows?
TomU
TomUAnswer
Try this:
mapkey qw @MAPKEY_NAMEClose all open windows;@MAPKEY_LABELQuit Window;\
mapkey(continued) ~ Command `ProCmdWinCloseGroup` ;~ Command `ProCmdWinCloseGroup` ;\
It will close up to 20 windows but Creo is currently limiting me to 18 windows open at one time.
People may better, but a cludge
We use qw to Quit Window (C is used as a prefix for our Create related mapkeys), and thus
qaw Quit All Windows - map have to be called a couple of times if there are alot of windows open
 Regards
mapkey qaw @MAPKEY_NAMEQuit All Windows;@MAPKEY_LABELQuit All Windows...[qaw];\
mapkey(continued) %qw;%qw;%qw;%qw;%qw;%qw;%qw;%qw;%qw;%qw;%qw;%qw;%qw;
mapkey qw @MAPKEY_LABELQuit Window...[qw];\
mapkey(continued) ~ Activate `main_dlg_cur` `page_View_control_btn` 0;\
mapkey(continued) ~ Command `ProCmdWinCloseGroup`;
MadhaviG1-VisitorAuthor
@cadcam Thanks for the reply and sharing the code but looking for more simplified solution. Specially for a big assemblies.
HamsterNL
18-Opal
We are using the same method.
QW = Quit Window
Then create a new mapkey that re-uses the "QW mapkey" multiple times to close multiple windows.
How many windows do you have open when working on a large assembly?
