Doesn't chamfered cone shape unbend support yet?
1. make a cone
2. sketched rip and chamfer
3. failed bend back
As a result, I want to bend the chamfered sheet metal to make a cone. Is there any other way other than this?
I added two cylinders to your model (diameter=916 and diameter=1100) ... see  following picture.
For both cylinders I did following steps:
  • unbend
  • chamfer 50 degrees
  • bend back
  • sketch using bent chamfer edge
Finding no.1
When chamfer surface is bent back then it changes from planar surface to curved surface.
This is why you cannot bend a bent cone back - Creo does not know how to deform chamfer surface.
Finding no.2
If you create sketch going through chamfer edge after bend back operation, you will get your angle.
At the top (diameter=916) it is 53.5 degrees.
At the bottom (diameter=1100) it is 52.9 degrees
So you know that the angle varies between two above values. >>> and this is the answer you are looking for (I hope).
  • unbend
  • bend back
Finding no.1
Finding no.2
kdirth
After a bit of experimentation, with a cone, it appears creo is unable to bend back a cone if you modify the end of the driving surface.
hyarth4-ParticipantAuthor
Yes that's what I wanted, but if this is chamfered inside the cone, it seems that bend back is impossible.
Could this problem be solved?
I opened model shown in my reply from ‎2023-02-24 02:37 PM, changed outer chamfers to inner ones and redefined Sketch features. Model was regenerated successfully. NO PROBLEM.
If you don't mind, could you upload the model file? I'll open the commercial version later.
I am sending data.
Thank you for your help!
