DOT 라인 스타일 화면상에선는 직선으로 보임 (DOT Line Style Appears as a straight line on the screen)
I am using Creo Parametric 3.0 M190
Sketch's DOT line style it looks straight on the screen, and you have to enlarge it to see it in DOT shape. Is there a way to see it in DOT shape on the screen?
Translated with Google Translate
Translated by Hedy Jin, Jan 6th, 2022
Sketch 의 DOT 라인 스타이 화면상에서 직선 형태로 보이고 크게 확대 해야 DOT 형태로 보이는데 화면상에서 DOT 형태로 볼수 있는 방법이 있는지요?
Hello @성박_01
If my understanding is correct, you would like to control the Line Style of Centerlines created in Sketcher environment.
If you confim my above understanding:
  • This is possible manually as shown in little movie attached
  • But there is unfortunately no config.pro option allowing to control the Sketcher's Centerline's Line Style per default
Serge
I guess that OP is asking why dotted line in sketcher is displayed as solid line, when he zoom out sketched entities. To see dotted line he has to zoom in sketched entities. Because OP did not upload any picture, I am not sure...
