Drawing changed but not changed
We have an assembly that the designer put too many mounting plates in. The drawing BOM showed 26 plates but only 24 columns. When he went in and removed the 2 extra plates from the assembly and then opened the drawing, he received a message that the BOM count quantity had changed from 26 to 24. All good so far, Checked out the drawing and with the change went to check it back in. Message appears that nothing has changed so nothing to check in. What is Creo thinking when it tells you that the BOM has changed but it isn't changed for checking back in?
Same thing but with a dimension. Changed from a single hole diameter callout to adding a 4X. Open the drawing, get notified that the dimension has changed, but nothing to check in due to being no change.
In both cases, we had to do something in the drawings to 'force' a change that Creo would recognize as a change to get the changes checked back in.
Very frustrating and in both had to open the drawings twice to realize what it would take to fix them.
If the software is 'smart' enough to know a change has taken place in the assembly or model to tell you that it has changed the drawing, that should be enough to let the file be checked back and get the change updated.
Is this a bug with Creo 7.0.10.0 or just something new that a change is not a change?
StephenW
StephenWAnswer
I'm pretty sure this has been a thing all along. I've seen it over and over. I just move a note slightly or something and save.
StephenW
StephenW23-Emerald IIIAnswer
