Drawing formats disappearing
I am using Creo Parametric - Release 6.0 (connected) 6.0 6.0.3.0
I can generate a drawing with formats but when I close and reopen the drawing the format is missing.
I am new to the software but I believe my working directory is all set up correctly.
Here are the errors that I faced
No errors thrown
    No errors thrown
    1.] Creo looks for .frm files in current directory
    2.] Creo looks for .frm files in directory  specified in config.pro option PRO_FORMAT_DIR
    I guess you need to set config.pro option PRO_FORMAT_DIR  properly.
    Could you walk me through changing this configuration
    please use PTC Help, for example https://support.ptc.com/help/creo/creo_pma/r8.0/usascii/#page/configuration_options%2FTo_Set_Pro_ENGINEER_Fundamentals_Config_O.html%23 page.
