Aug 31, 2018 2:05 PM UTC
Drawing Only Displaying in Wireframe
Hey all,
I am currently making a drawing for a simplified rep of a large model. When I want to use "No Hidden" for display and "None" for tangent edges, my model will only display in wireframe, which pretty much freezes up Creo because of the massive amount of CPU being used. Is there a way I can fix this?
StephenW
Aug 31, 2018 2:15 PM UTC
With large assemblies and simplified reps, you need to make sure you only open up the rep you want to work in and not the master rep. Make sure your drawing only references the rep you want and not the master rep.
What are your computer specs? RAM? Video Card?
There is not much that helps speed up large assembly drawings but having enough RAM and having a good video card will at least let you work without crashing.
EthanT241-VisitorAuthor
Aug 31, 2018 2:28 PM UTC
The active rep that I am using in the drawing is the simplified rep. The problem is that when the model is "temporarily displayed in wireframe", is when I start experiencing issues. My question is what could be causing the model to do this whenever I try to set the view display to "no hidden"?
StephenW
Aug 31, 2018 2:44 PM UTC
It's possible you are just running out of RAM. Maybe your video card isn't capable of handling the load.
There are some config.pro settting you can use for adding views to eliminate the wireframe preview but if you are that close to crashing already, it might not help.
auto_regen_views NO
display_in_adding_view minimal_wireframe
disp_trimetric_dwg_mode NO
There may be others. These are what I found quickly.
Sep 7, 2018 10:18 AM UTC
I have tried adding the view with the desired DS, changing after a view was created, making a Configuration where the enveloping part is wireframe, and toggling between HLR and wireframe on all the views.No difference on the drawing - the view will show the model in the default HLR mode. Toggling the view Display Style changes all parts in the assembly at the same time.
 I suppose I could as a work-around use shading and printing to a "black & white"PDF. That actually makes it greyscale and the view becomes a great big blotch, but it is at least in the vicinity of the desired result...
StephenW
Sep 7, 2018 12:17 PM UTC
What exactly are you trying to do?
Drawing view display is for the entire view.
Under the layout tab, there is a component display that you can use to set a component to a different display.
If you include a screen shot of what you want or what your problem is, maybe we can help.
