May 28, 2014 7:23 PM UTC
Drawing Overlays
Does anyone have any experience/comments on using drawing overlays in a WC system to combine large drawings (>100 pgs)?
Corey L. Jones
Design Engineering Systems Specialist
Principal Engineering Technology Development Group
ESC - Team QNA
SGT Inc.
Kennedy Space Center, FL 32899
NOTICE . . . The information contained in this communication may be sensitive, proprietary, legally privileged and/or subject to U.S. export control laws, is intended only for the use of the recipient named above. You agree to comply strictly with all U.S. export laws and assume sole responsibility for obtaining licenses to export or re-export as may be required. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication, or any of its contents, is strictly prohibited. If you have received this communication in error, please re-send this communication to the sender and delete the original message and any copy of it.
cljones71-VisitorAuthor
May 28, 2014 7:35 PM UTC
From Creo Parametric Help
About Using Drawing Overlays
Using overlays, you can superimpose selected views or an entire sheet of one drawing over the current drawing sheet. This functionality is available for drawings, layouts, reports, and diagrams; each can reference objects of these four types, as well as formats.
When working with overlays, remember the following points:
Overlays are read-only in the current drawing.
The system updates overlays to changes in the source drawing.
Overlaid views appear with all detail items.
You cannot select overlays for any drawing procedure.
If the size of the current drawing is different from the size of the source drawing, the overlays brought into the current drawing maintain the same screen size (that is, they occupy the same portion of the graphics window) as they had in the source drawing.
[cid:image001.png@01CF7A8A.75C53E10]
Corey L. Jones
ESC - Team QNA
SGT Inc.
May 29, 2014 12:22 PM UTC
This would be a great tool if you could "overlay" revisions in Windchill...or can you?
May 29, 2014 12:55 PM UTC
If you have the MCAD upgrade for CREO View for Windchill, then you have the ability to compare drawings and models.
Brian Toussaint
Systems Administrator
Hoshizaki America, Inc.
"A Superior Degree Of Reliability"
618 Hwy. 74 S., Peachtree City, GA 30269
May 29, 2014 1:23 PM UTC
Can you expand on how to do this? I have MCAD but when I use "Compare to" my fly out is empty. Thanks!
May 29, 2014 1:39 PM UTC
When you select Drawing #1 in the Viewables navigator, do you see the option to "Compare With"?
Madhavi
vizpundit.com
May 29, 2014 1:43 PM UTC
I select both using <ctrl> and then right click.
[Description: C:\Users\BTOUSS~1\AppData\Local\Temp\SNAGHTML9ef8ff3.PNG]
Brian Toussaint
22-Sapphire I
May 29, 2014 2:32 PM UTC
It's takes a bit to dig out of the documentation how to use, but Drawing Overlay is one of the absolutely essential tools in the system.
We require all checks to be done using it - have done so far 12 years now, going back to Intralink 3.x and separate Division ProductView.
Important - Only available if you publish to PLT still I think, not if you publish to PDF. This was our overwhelming reason to use PLT instead of PDF some years back; not sure if still true but expect so.
May 29, 2014 2:36 PM UTC
Correct it doesn't do PDFs. That's on 10.1, doubt that it changes for 10.2.
Brian Toussaint
May 29, 2014 3:38 PM UTC
No change in 10.2. PDF compare was in my backlog for support in a future
release (before I left PTC couple months ago).
Hopefully, PDF compare will be supported in the next release..
Madhavi
May 29, 2014 4:11 PM UTC
I am aware of the functionality of Creo View to compare 2d drawings (I am the TC Chair for Visualization). My design organization would like to create drawings by using the Creo Parametric function of "Overlay" . These drawings would be considered released engineering when completed, however I am concerned this may cause relationship/reference issues in WC. It looks like Creo Parametric overlay function has been utilized very sparsely.
Corey L. Jones
ESC - Team QNA
SGT Inc.
