May 25, 2013 5:30 AM UTC
drawing program
hi everyone,
Can anybody tell me that is it possible to delet a drawing view automatically by drawing program???????????
May 25, 2013 10:41 PM UTC
You question is not clear. Drawing views can be deleted but there is nothing "automatic" about it. If you are using templates with pre-defined views that you do not want, you may want to use a template without pre-defined views instead.
May 27, 2013 5:00 AM UTC
Thanks for ur suggestion,
but can u please tell me that how we can pre-define the views in drawing template??
i am using pro-e wildfire 5.0- creo.
May 27, 2013 8:05 AM UTC
You create a drawing with the view you want and save it in the template folder. When you open a new drawing, you have the option of opening a template, which is simply a drawing file.
There are setting in config.pro to set custom locations for drawing templates. I recommend using these so you don't accidentally loose your custom templates when you update the software. The default location for templates are ...\Creo 2.0\Common Files\M040\creo_standards\templates (and others)
Aug 31, 2017 5:14 AM UTC
you can use parameter in part or assemble, the desired views you wanted to hide depend on the parameter seleted.
