Drawing Sheets Split
Hi Guys,
I have one main assembly that has one drawing and also I include my sub-assembly and component drawing based on sheets. Can we convert it into individual drawings based on the 3D model name?
Aj
StephenW
I don't think you can do anything based on model name.
In a drawing, you can import drawing data from another model. So you could make a new drawing, import the drawing already have and then eliminate the detail you don't need
There is also and overlay function, but i don't think that would be applicable to your request.
Thanks for the replay @StephenW
I have more than 1000 drawings in one drawing I have multiple sheets based on sub-assembly i want to maintain individual. Can we use "Creo Distrubtion Batch" method to make a individual drawing. [Drawing is linked with CAD model so don't want same as CAD name]
Aj
