Drawing symbols disappear, why?
Hi all, this is a strange one....
I have a Creo 2 drawing. I can place custom symbols as free entities without problem, I can also use the "on entity" placement and this is also fine providing I select some edge geometry to place it to.
However!.... if I choose to use an "on entity" placement and select the leader line of a dimension, the symbol will disappear after a few minutes. I can use the find tool to relocate it, but it's not visible or printable on my drawing.
This fault occurs regardless of which symbol I choose (I have tried a few), and as a test I have created a brand new drawing, using the same model, and successfully placed a custom symbol on a dimension leader line. There must be something up with the original drawing???
Any ideas?
menderAnswer
Another thing to check, in your old drawing, update to versioned fixes by the detail setup command update_drawing.  The reason for this is that a fix that affects symbol visibility would require versioning to avoid changing the appearance of an existing released drawing on retrieval.
Workflow:
File > Prepare > Drawing Properties > Detail Options > "update_drawing" for the 'option name', and "all" for the value.
then add this symbol, and see if it now stays.  If it does, then all is good, unless some other fix corrected by the update changes your drawing's appearance in a way you don't like.  If that is the case, you can file an SPR to have us hunt down which specific versioned fix is the one that addressed this issue, and you can update to only that one.
Check your layers.
I have a drawing program in our template drawings that puts symbols on the drawing depending on drawing classification. After modifying the program, some drawing sizes put additional symbols on a hidden layer that is not active. We can locate them and then cut and paste them back to a visible layer. Never have figured out how to prevent it or to make a certain layer the 'active' layer when the drawing program exits.
mender12-AmethystAnswer
Workflow:
I can't say as I understand it... but your reply has fixed my problem. Many thanks.
StephenW
Ahhh, let us proclaim the mystery of our CREO!!!
