2-Explorer
Mar 9, 2011 5:05 PM UTC
Drawing Views Shift Right
I have a strange situation with a drawing of an assembly.
On my machine, with my Config.pro, the drawing displays perfectly well. On
another machine, using a different config.pro, the drawing views disappear
off to the right, off the format and leaving the dimensions and notes
behind. If I replace my config.pro on my machine with the other one, I get
the problem on my machine, too.
Simple, I thought, I will go through the differences between the config
files one-by-one and pin down the culprit. It's not that simple. I have
tried the top half/bottom half approach - I removed the top half of the
differences - the problem did not appear. I removed the bottom half of the
differences - the problem did not appear. I have tried to work through and
isolate individual differences, but it is proving very long-winded. I am
worried it may be due to a number of config items interacting, in which case
I could be here a very long time. Do you have any ideas where the problem
may lie? Perhaps you have observed this behaviour before and have tracked it
down. maybe you are just very knowledgeable about config files. Whatever, I
would certainly welcome some help.
WF2, M220
Jan 12, 2017 8:45 PM UTC
John,
Did you ever find the cause of this?  I am experiencing the same problem now.
Creo 3.0
Jan 12, 2017 8:52 PM UTC
That's very strange.  I would recommend contacting support and getting an SPR filed, so I can have the job of hunting down the cause.
