Drill on extruded Drawing as reference
  • November 12, 2015
  • 1150 views
My name is Peter. I have extruded an drawing in Creo 2.0.
Now I want to drill holes beginning from another layer.
As reference for these threaded holes I want to use points of the Drawing which I extruded from.
I attached a picture of the part.
18-Opal
November 12, 2015
Hi Peter,
I am not sure I understand the problem you are running into.  I just tried putting a hole feature, using a datum point as a reference, and was able to do is successfully.  Please upload your model here, and I can investigate further.
Amit
