8-Gravel
DRW to DXF export changes from mm to inch
The PRT which is the drawing based on has International System units (mm) settings.
Whenever the generated DXF is opened, the Creo 9 drw convert dimensions from mm to inch and it is not intended.
I'm not being able to find conversion in the drawing module. Don't know if the conversion occurs in the DXF exportation or in the drw generation from the exported DXF.
You are in the wrong forum.
PTC has two CAD systems:    Creo+ and Creo Parametric    and     Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
Emeritus
Hi @CarlosCaseras
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
