DRW to PDF, but resize the sheet
We currently use the export to PDF to 'lock in' our released parts & assembly drawings. But, we seem to have an issue with the page size. We do all our drawings on a B sized sheet (11"x17"), but would like our PDFs to contain the same format, but be exported to an A sized sheet (8.5"x11"). (Some users can't seem to figure out the 'fit to page' button in acrobat!)
Yes, we can 'print to' a PDF, and select the sheet size. It seems to retain certain colours & other features. And we can also export as PDF, then open the PDF in Acrobat & re-print from there to resize it.
Curious to know if there is a Creo 2 command, short cut, config parameter, etc.. that we don't know about.. Does the 'export' command have any advantages over just the 'print to' option. Do we loose anything? Do we gain anything? thoughts?
thanks!
paul
