duplicating an assembly
I am a newer user of Creo Parametric 6.0 as well as to CAD in general.  I have been learning it on my own and have used a number of resources to learn the basic concepts.
I have created an assembly for a clamping fixture.  However, I would like to expand the fixture from the current two stations to a total of ten stations.
Is there a way to basically copy (or duplicate) the existing assembly and add four additional assembles to the side to accomplish this task?  Or should I start from scratch ?
Thanks in advance,
Tim
There are many options.
Grouping the components will make it easier to copy them as a single unit.
If the spacing is uniform between your clamps, you can pattern the group to place the additional clamps.
Another option: If the clamp assembly is being used in multiple locations or may be used in multiple files, create it as a standalone assembly and bring that into your fixture assembly.
Thanks. I'll give that a try.
It sounds to me like you need 3 assemblies.
  1. Clamping fixture assembly
  2. Station assembly
  3. New assembly to place other 2 assemblies
You can assemble your stations in a new assembly and then assemble your clamping fixture to those stations.
The hierarchy in your model tree would look like this:
 newassembly.asm
    - stationsassy.asm
    - stationsassy.asm
    - stationsassy.asm
    - stationsassy.asm
    - stationsassy.asm
    - clampfix.asm
    - clampfix.asm
    - clampfix.asm
    - clampfix.asm
    - clampfix.asm
Depending on how modular you want it, the structure could be:
 newassembly.asm
    - stationsassy.asm
        - clampfix.asm
- stationsassy.asm
        - clampfix.asm
- stationsassy.asm
        - clampfix.asm
- stationsassy.asm
        - clampfix.asm
- stationsassy.asm
        - clampfix.asm
