6-Contributor
Aug 23, 2022 7:30 PM UTC
dwg import problem into sketch
I am using Creo Parametric Release 9.0 and Datecode9.0.1.0
When I import dwg file into sketch, I had an error.
Here are the errors that I faced
RealDWG is not installed on your machine.
Please consult your administrator about installing this application.
    Aug 24, 2022 10:22 AM UTC
    This is the article you will find when searching "RealDWG" in the knowledge base: https://www.ptc.com/en/support/article/cs316600
    6-Contributor
    Aug 24, 2022 1:40 PM UTC
    Thanks for reply. But I can open the same dwg file with creo 8.0, which is interesting.
    Aug 24, 2022 2:28 PM UTC
    Successful opening in Creo 8.0 is actually good news: you have a working environment.
    If we stick to the meaning of the error message, the application RealDWG needs to be installed. But can confirm that Creo 8, Creo 9 and RealDWG are installed on the same workstation?
