DXF file export
I exported DXF files of PCB shape with default settings(Exported .dwg files to .dxf). When these files were opened in Altium, the notes were missing. Needed help in understanding what settings are to be made so that the notes are seen in DXF file when opened in Altium.
please upload Creo files and exported dxf file.
Thanks for the response. Unable to attach the dxf file. Is it possible for you to suggest what setting is to be adopted.
I do not want you to publish secret data. I hope you can create simple test model, test model and test DXF and upload these dataset. Also I hope you can publish screenshots of Creo window and Altium window.
