BHurler
11-Garnet
Easiest way to add restricted parameters to Models?
Creo has neat functionality in the restricted parameter list.  Creo also has nice functionality in that you can import an .xml file to add parameters to a Model.  It would appear that these two do not play well together.
I am trying to update legacy models that have missing parameters and my .xml import was working wonderfully until I updated my restricted parameter.lst file.
I get this message:
Is there any way to make the import work?  Is it a matter of my restrictions in my .lst not EXACTLY matching what I have in the .xml?
BHurler
BHurlerAnswer
11-Garnet
I created a mapkey that hits the + sign at the bottom of the parameter window.  If there are restricted parameters that have not been created, it adds them one by one.  If there are none left, it adds parameter_1, parameter_2, etc., ...
Article - "Full Access parameters used in relations cannot be imported via xml file in Creo Parametric 4.0": https://www.ptc.com/en/support/article/CS297809
Community Moderator
Hi @BHurler,
Anurag
BHurler
BHurler11-GarnetAuthorAnswer
11-Garnet
