ecad_hint.map
Need some ECAD import help. On WF5 w/Intralink.
I created the ecad_hint.map below and placed in my local start up dir
and assumed it would map the ecad name to my pro/e name and swap out.
This is with the understanding that the pro/e files do match the cso's
of the ecad parts.
Not working. What can I do to make this happen?
WayneF
Map_objects_by_name ->
ECAD_NAME "CONN2375X1841X782-15_PTH"
ECAD_ALT_NAME "1AB169630003"
ECAD_TYPE " "
MCAD_NAME "836129020"
MCAD_TYPE "part"
MCAD_LAYER "CONN2375X1841X782-15_PTH"
END
map_objects_by_name->
ECAD_NAME "CONN3119X2120X1360"
ECAD_ALT_NAME "1AB003150026"
ECAD_TYPE " "
MCAD_NAME "C-5747020-01-A-3D"
MCAD_TYPE "part"
MCAD_LAYER "CONN3119X2120X1360"
END
ECAD_NAME "JK3641X1496X1613-4"
ECAD_ALT_NAME "1AB006020028"
ECAD_TYPE " "
MCAD_NAME "C-227161-2-AF-3D"
MCAD_TYPE "part"
MCAD_LAYER "JK3641X1496X1613-4"
END
ECAD_NAME "CONN2885X5573X1310-30"
ECAD_ALT_NAME "1AB367330004"
ECAD_TYPE " "
MCAD_NAME "CM-111112-1270-674760"
MCAD_TYPE "part"
MCAD_LAYER "CONN2885X5573X1310-30"
END
ECAD_NAME "CONN1100X840X540-20_V1"
ECAD_ALT_NAME "1AB434950001"
ECAD_TYPE " "
MCAD_NAME "744410001_MOLEX"
MCAD_TYPE "part"
MCAD_LAYER "CONN1100X840X540-20_V1"
END
Wayne,
I think there is a config option ecad_mapping_file that sets the path to the hint.map.
jef
wfalco16-PearlAuthor
Yes. But I read it defaults to root dir. That is where I placed my .map
file. I suppose I can try to set that.
I just noticed it is pointing elsewhere. I am changing path and will
retry. Thanks all.
My real issue seemed to be that it must be written in lower case.
Well......that's what worked anyway.
