ECAD MCAD Collaboration
  • September 2, 2015
  • 4 replies
  • 3483 views
I am working with ECAD MCAD collaboration module. I find options like set as accept, set as reject are greyed out. What could be the possible reason?
I use Creo Parametric 2.0. I tried with both View 2.0 & 3.0 M031.
Dhinesh
Hi Dhinesh,
Did you ever find a solution to this problem? I have exactly the same problem. If you found a solution, could you please forward it to me at msodoma@gnresound.com? We are using Creo 3.0, M040 and Creo View 3.1, F000. (I tried using Creo View 3.0, M031, but that did not work either.)
Mark
dm-31-VisitorAuthor
The Allegro file is a baseline IDX and does not allow preview, cross-select, or accept/reject for that type of IDX file. Only incremental IDX files will have this functionality enabled.
In Creo View you can open baseline IDX to see what it looks like.
MarcoTosin
What do you mean with incremental?
IDX = Incremental Data eXchange (see below link)
IDF, IDX
Marco
