Feb 13, 2014 2:55 PM UTC
ECAD related Document Types ECAD Neutral
Hello ECAD users
We started the implementation of Windchill in our company a couple of weeks ago.
In our company, we use Zuken CADSTAR for schematic and PCB. Well, CADSTAR ist not supported with a WGM, so we need to use the ECAD Neutral.
Right now, i'm trying to identificate what each of the ECAD related CAD Document types does.
ECAD related CAD Document Templates
  • ECAD - BOM Attributes Mapping <= mapping file between Windchill BOM and ECAD Software
  • ECAD - BOM Filter Definition <= Filter file for BOM, like Attrivutes we don't want to map to Windchill
  • ECAD - Content <= ? don't know what this one does
  • ECAD - Content Definition <= document pointer, like "in this folder is a file is a *.pdf file. Use it as content"
  • ECAD - Documentation Data <= ? don't know what this one does (Blueprint PCB Software)
  • ECAD - Drawing <= <= ? don't know what this one does
  • ECAD - Manufacturing Data <= ? don't know what this one does (CAM350 Software)
  • ECAD - MCAD Exchange Data <= Derived Data , we use it for IDF data
  • ECAD - Packaged View <= ? don't know what this one does
Hope someone can explain what the other document types do. I'm specially interested in ECAD - Content. Whats the difference to ECAD - Content Definition?
Best regards
M.Suarez
Feb 13, 2014 5:00 PM UTC
I hope to be following up with documentation soon but for now I hope this helps.
    DAVE: Mapping the fields ( Column Headers)
  • ECAD - BOM Filter Definition <= Filter file for BOM, like Attributes we don't want to map to Windchill
    DAVE: Correct
    DAVE: this document is a container for data that is created from the ECAD database and associated to a design .
    Example:
    MFG data, Test Data, ASSY data.
    DAVE: I would describe that as the instruction of what to collect and attach to Content.
    Example
    Content = MFG data,
    Content Definition = from this location c:\abc\desin\output\ collect *.GER, *DRL, drill .pdf.
    DAVE: Blueprint-PCB is a documentation tool from Downstream Technologies http://downstreamtech.com/
    the document is a container for Blueprint-PCB
    DAVE: this is kind of a generic document container you may want to collect misc. document and have them be checked in.
    DAVE: CAM350is a Gerber management/visualization tool from Downstream Technologies http://downstreamtech.com/
    the document is a container for CAM350
    DAVE: you are using it as expected.
    DAVE: I don’t have firsthand knowledge but looking into it.
Feb 14, 2014 11:22 AM UTC
Hi Dave,
thank you for your reply.
greetings Marcos
Feb 17, 2014 9:06 PM UTC
Marcos,
With regard to your ECAD data model question;
I gave a discussion last year at PTC Live. This Presentation might be of use to you and your team for some good graphic presentation of how the items configure and interact.
Regards,Scott Claes
info@claes.biz www.claes.biz
Twitter LinkedIn
