Editing Overriden Dimensions Text
This has actually bothered me for quite some time, so hopefully I will get a good answer to resolve my dilemma. Occassionally I need to override dimensions, I hate to do it, but sometimes it's unavoidable. When I have a dual dimension, and I enter the text for the secondary dimension (in brackets) tolerance of +xxx/-xxx (PRO Code @++xxx@#@--xxx@#), the brackets are always normal text height, aren't big enough to encompass the tolerance and makes the overridden dimensions with +xxx/-xxx look different. This causes a problem when we use +xxx/-xxx tolerancing, because on the same drawing with shown or user defined dimensions, the brackets are big enough to encompass the tolerance. How can I edit the overridden dimension to appear the same as a shown or user defined dimension.
