Dec 8, 2015 1:01 PM UTC
Enforced displacement, tangential direction, more than 1 revolution
I've been doing some experimenting with large deformation analysis.
I want to twist the end of the beam around, several times (don't ask why, I just need it done).
In a large deformations analysis you can not prescribe a tangential displacement in radians. It has to be "unit of length" mm in my case. So I did this for the circular curve on the end of the tapered bit
I get it to rotate about 360 degrees, no further, however large I make the value for prescribed displacement (the value in the field is now 9000mm (160 full turns....).I stopped the analysis after I found out that displacements no longer increased.
Any body knows how to tackle this?
Shall we classify this as a bug?
Dec 8, 2015 1:17 PM UTC
What about the "interpret angular translations in radians" check-box?
Could you attach your end face to a single point using a rigid link (or a weighted link and a spring), and apply a rotation to the point?  You could try applying that rotation in a Cartesian csys to see whether that works any better...
ehaenen1-VisitorAuthor
Dec 8, 2015 1:33 PM UTC
Jonathan:
The interpret etc. is not allowed for large displacements, this is definitely large displacements, So I can not use the check box.
I'll try with the point and the link(s) as soon as my regular analysis completes, but I fear.......
Well let's not get ahead of that.
I'll keep you informed on the developments.
Erik
Dec 9, 2015 10:05 AM UTC
I tried to circumvene te problem by applying a load instead of a displacement.
Unfortunately I seem to be running into the same limitation: the model runs fine up to 360 degrees, but does not want to go beyond 360 degrees rotation.
Declaring it a bug sounds like a good idea, let's hear why this is such an impossibility. If PTC wants to go nonlinear they should do it right.
Dec 9, 2015 10:11 AM UTC
Jonathan
Rigid link and prescribed rotation around z-axis on the free point worked. looks great, Thank you!
Video Link : 6562
Will look into the instabilities, but this is 600 degrees of rotation.
