Engineer
I am using Creo Parametric - Release 4.0 (connected) 4.0 M060
New linestocks were created for Newberry CAD conversion. When I add a hole as a UDF (user defined feature), not only does it not add the hole feature to the bend table, it stops the bend table from being created at all. When initially setting up the hole UDF, it indicates that the files do not have the same units. I've tried to change units in the tube part/assembly, and change scale of the hole, but have not had any success.
Example is 31350642
"Chart Generation ERROR: 3010 = Pipe Hole Has Invalid Diameter"
@SS_9984976 Working on the issue through the salesforce case 15995580
