entity line high thickness in printout
- 4 replies
- 2871 views
- Translate All
I'm using Pro-E WF5.0.. i have some problem on drawing printout.. when i take print, entity thickness is to high as in the image i attached...
i also gothru some discussions.. they take about to change the PEN_TABLE value... but i cannot found the option.. pls give me the step by step options, how to add & edit the pen_table value in config .pro... pls help me to solve this problem..
