Feb 9, 2010 7:27 PM UTC
Eplan - Pro/Cable integration
I believe that the RSD to Pro/E integration is done through XML.
Anyone ever heard of Pro/Cable and Eplan integration?
We use Eplan but would lobe to drive Pro/Cable with it.
Aug 6, 2016 9:18 PM UTC
We are struggling with the same problem. Did you find any solution for eplan integration?
vmcdaniel1-VisitorAuthor
Aug 8, 2016 8:06 PM UTC
We did not find a solution.
Aug 29, 2016 3:39 PM UTC
Hi, I worked for a client recently and they worked in eplan while the mechanical guys were in CREO. I can't say it was very successful form a CREO point of view and to be honest I think the electricians did whatever they wanted. They did however generate a 3d eplan assembly that could be dropped into CREO. The biggest issue was the scale of the job was way beyond what had been attempted before.
Oct 6, 2016 7:54 AM UTC
We are also looking for EPlan 2D schematics integration to Creo through XML, any inputs on that? i saw some video for SolidWorks
Oct 25, 2016 4:34 PM UTC
To my mind EPLAN is working for an cabling data Export to Creo.
If you need informations you can contact me.
Oct 26, 2016 6:24 AM UTC
The principle should be similar to RSD.
But it is not a few words can say clearly.
Oct 26, 2016 6:31 AM UTC
It's the same principle,
Im- and Export via XML Structures.and an addon for EPLAN P8
Oct 26, 2016 6:33 AM UTC
The key is how to define attribute in EPLAN
