Erasing lines in sectioned view in a proe drawing
Hi All, In a proe drawing, I have 2 views. Front and left views. I created a cross section in left view. Now I want to erase those lines in left view which are produced as a result of creating cross section. Is it possible? If yes, how? Ankur
August 31, 2009
Entity lines: View/Drawing display/edge display/ease line
The lines I want to erase are not entity lines. These are a result of cross section (I mean these are intersection of cross section plane and solid surfaces). I tried using edge display/ease line, but could not do it. Is there any other way?
I'm glad you clarified the lines you wanted. The cross section lines could be set on spacing such that they are not longer visible in the section view. Or you could change the type of cross section lines so that they appear better on the drawing. Section views are supposed to have cross section lines by definition, but sometimes people don't always follow drafting standards.
