Error opening SCHEMATICS file
I have this error when opening
?msg_msg@Probe the components or geometry you want to select
?msg_msg@Serious error - could not recover corrupt design
?msg_err@>>>> error <<<<
?msg_err@Failed to open the design. It may be corrupt or inaccessible. An automatic backup was saved to:
Y:\ARQUIVOS OFF LINE\RMendes\DEFENSIVO\0000014403_6-22-2023_RCV_1.rsd.
Gaby_KAnswer
  • for some reason , the design is corrupted:
  • did you try to open the automatic backup :
if it does not work for you, report the issue to Technical support
Gaby_K12-AmethystAnswer
