evaloutline issue
- 5 replies
- 3324 views
- Translate All
Hi all,
I want to retrieve bounding box dimension of a model. I use IpfcSolid.Evaloutline(), but the return value dosent reflect the actual size. I have attached the image of results for 600X325X10 outline calculation. Kindly throw some light why there is a deviation. This is not the same when I use IpfcSolid.Geomoutline().
