Examples of BOM.FMT
I am using Creo Parametric Release 8.0 and Datecode8.0.3.0
Want to create custom BOM.FMT Wondering if some existing BOM.FMT are available to use, to start from.
    Hello @dtrabattoni
    You'll find an example "ready to be downloaded for use", and also a very clear guidance on how you can "tune" it starting from stepc described in our article 70231.
    => Once done, remember to add bom_format option in config.pro, and provide as value the full path and name of the BOM source file (*.fmt).
    Hope this helps,
    Serge
    Hello @dtrabattoni
    Hope this helps,
    Serge
    THANK YOU SO MUCH !
