Excel Linkeage
Hi Guys,
Can we use the "Excel Analysis" to get a parameter value into excel if I change it in excel it'll update in the 3D model. it's possible
AJ
tbraxton
Maybe. You have not provided enough detail on exactly what you need to do. If the parameter(s) in question comply with the constraints below, then it should be possible.
Input values for the Excel analysis can be the following:
•Model dimensions
•Top-level model parameters
•Analysis feature parameters
