EXCEPTION_NONCONTINUABLE_EXCEPTION
I am using Creo Parametric - Release 3.0 (connected) 3.0
I was working on several parts in a workspace and each independent of each other. Creo would randomly crash when saving, modifying, opening, and/or removing the part files. I was able to remove the files eventually and started in a whole new worskpace and checked out new files. The same error repeated itself "Exception EXCEPTION_NONCONTINUABLE_EXCEPTION". This issue would cause a fatal crash to Creo on average twice per five minutes. All files that were used to test and find the pattern on what was causing the issue were randomly selected and disconnected from each other. Sometimes the same part and sequence would work without error and sometimes that same sequence would fatally crash.
Here are the errors that I faced
Exception EXCEPTION_NONCONTINUABLE_EXCEPTION has occurred in the thread 6920
    A clean uninstall and wipe of all creo files followed by a reinstall of the program was what finally fixed this problem.
    Check out the suggested solutions in this article ("The traceback contains an error description like: Exception EXCEPTION_ACCESS_VIOLATION has occurred in the thread ####"): https://www.ptc.com/en/support/article/CS49550
    SS_101567661-VisitorAuthorAnswer
