3-Newcomer
Exploded View error using User-Defined Simplified Reps
I have a top assembly that has multiple parts that have threads in them. In the part level, they each have a no-threads simplified rep that deactivates a feature (helical sweep) to remove the threads. Note that nothing else is referencing the sweep in features/assembly. In the top level, I have a simplified rep that sets every other part as master while the parts that have threads in them as “User defined” using the no threads rep of the said parts. This works fine as is in changing simplified rep but when you try to create an exploded view, the parts that are user-defined just breaks and not follow the explotion state both in CAD and especially in drawing. You can manually move it in CAD to make it look good but in drawings, they just move around every time.
It looks like there’s a similar case in here just in case people have come accross this one for some insight -
