Exploded View in Parent
I was working with exploded views that can be pulled from the subassemblies to the parent using the default explode. However the explode lines from the subassembly are not showing in the parent. Is that how its supposed to work or am I missing a setting that can bring the explode lines into the parent?
Community Moderator
Hi @ZC_10909252,
Thank you for your question.
Anurag
