Exploded Views - Subassembly
Community,
I have an assembly that has a sub-assembly.  I would like to move the entire sub-assembly (keep all the components together) from the main assembly, all within the exploded view environment. When I try to merge components, I get two colors, and I do not want that.  Can this be done?  Thanks in advance.
ThoRigAnswer
Edit Position>Translate>LMB Subassembly>RMB Pick List>LMB Subassembly.
That works.  Thanks.
kdirth
To move a subassembly in explode either select the subassembly from the model tree or use query select (right-click) to select it from the graphics window.  If this is not a true subassembly, but a group of parts, you can either hold Ctrl and select all of the parts and move together or move one and copy its position to the rest.
ThoRig14-AlexandriteAuthor
It is a true subassembly.  I tried selecting it in the model tree, but nothing happened.  I will try it again this morning.  I know that I can use copy geometry (surfaces) and merge all the surfaces, but I was trying to find a quicker way.  Thanks.
