Export Creo File without model tree history
Hi all,
Is there a way to save a Creo file without the model tree history?
I need to send a large assembly in Creo format to a client, but I don't want him to have access to the parametrization.
I know I can save as a step or igs and then convert to creo again, but I'm wondering if there is a more direct way to do this.
18-Opal
Depending on the end goal... a NEUTRAL File -- disabling the Parameters and Annotations works pretty well also..
StephenW
Shrinkwrap.
FILE -SAVE AS - SHRINKWRAP.
You'll need to experiment with the settings.
18-Opal
hdasilva14-AlexandriteAuthor
I have tried both options, neutral file and shrinkwrap.
Shrinkwrap doesn't work for me because it merges all parts and asm into one solid.
I need my client to have access to all parts and asm separately.
I'm still battling with neutral file, I think it can do the job, the problem is when I open the neutral asm, it prompts a windows to import each part and I have hundreds. I'm trying to get through this.
Thanks!
Ok, I just have to unselect the option "Customize layers" when importing:
