Export in JT file in CREO 2.0
  • January 19, 2017
  • 1818 views
Our CADs specialists are currently running CREO 2.0 M220. They need to export file in JT format.  We understand that this will require an additional license  INTF_for_JT.  Is that correct?
Moreover, we have also understood that in CREO 4.0 the interface for JT is already included in the baseline. Is that correct too?
I don't believe this is correct.  I have Creo 4.0 installed and I do not have the option to save to a JT file.
Here is an article that seems to confirm this (even though not updated yet for Creo 4):  https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS70279
