Export multiple DRWs to PDF
I need to export multiple DRWs to PDF,
I tried with Creo Distributed batch but it only got a maximum of 10 DRWs,
If it exceeds 10 DRWs, the process will be stopped
Tuan_HQAnswer
Could you pls explain more detail how to set system environment variable DBATCH_FORCE_CREO_RESTART Y
according to https://www.ptc.com/en/support/article/CS350192 article, you can set system environment variable
DBATCH_FORCE_CREO_RESTART to value Y
If variable is set then Creo Distributed batch restarts Creo session after every single export.
If it does not resolve your problem, then you have two options:
  • contact PTC Support
  • generate trail file and play it
Tuan_HQ10-MarbleAuthorAnswer
go to google.com and search for:
windows 10 set environment variable
-OR-
windows 10 set environment variable youtube
You will get a lot of links ...
