EXPORT PVS/PVZ RECIPE FILE
Hello to all,
I'm trying to export a Creo Parametric assembly in pvz that contains annotations both at the assembly level and at the part level.
Annotations are found in several combined states.
The latter are exported to the pvz and I display them in Creo View 6.0.
However, only the combined states of the assembly are exported, but not those contained in the parts.
Is there a possibility to do it? If so, how?
Thank you,
Matteo
