Export Technical data
I have to investigate how to export technical data from my assembly to a external file (text, Excel...) with the following assumptions:
* My product is configurable. I may have to remove some compoennts and add others.
* My product can have different positions. For example, I need center of gravity in different positions
I know how to add / remove components with Pro/Program
I know how to get movement with Mechanism or skeletons
"Inteligence" could be done in JLink
It seems quite complicated. I thought I might ask if you have done something similar, and which is your recommendation.
Best regards
Daniel Garcia
