HamsterNL
18-Opal
Export to IFC
We have the requirement to work in a BIM environment, by exporting our 3D models to the IFC format (Industry Foundation Class)
We have both WF4 and Creo2.0
How can I export my assemblies to IFC?
HamsterNL
HamsterNL18-OpalAuthor
18-Opal
Is nobody working with IFC?
Any PTC employee willing to comment?
Hello Teun,
This year I investigate the possibilities to convert a Creo Elements Direct Modeling model to IFC. If you been interested send your mail adres to CreoApps4You@outlook.com so that i can send you some information.
Best regards,
Ronald.
HamsterNL
18-Opal
Hi Ronald,
If you have something to share...please share it here for the world to see. There's no need for me to send you an email, especialy if this is the first post from you on the PTC Community. As you can tell, I am not interested in any commercial software, just a solution from PTC.
Hope you understand.
Patriot_1776
I'm down with IFC (Yeah, you know me!).
(Sorry, a little "rap" humor from the early '90's)
HamsterNL
18-Opal
Frank, you are "naughty" (by nature) 😉
Patriot_1776
Hah! SOMEONE get's it!
I have tried exporting my model with the inbuilt IFC exporter. But I could only open it in revit as a single block, which was a big concern. After a lot of research, I tried a trial version of bim-dex plugin. It helped the IFC file maintain the classes and hierarchy inside revit as per my client's requirement. Hope this helps your use case too!
Refer to https://www.ptc.com/en/support/article?n=CS163657 for workarounds
