Exported part cys axis interchanged
I tried to export my part as step  with different default cys
But in my result step file the default cys z and Y axis are interchanged.
Check image for details.
Help me with a solution.
Ram R
Designer
KenFarley
You did not include any image.
Regardless, to output with a different CSYS than the default, you need to click the checkbox "Customize Export". Then when the little dialog box for "Export STEP" comes up, you have to explicitly pick the coordinate system you want instead of the Default that shows there.
