Exporting gyroid or diamond structures as STEP or IGES file
I have created gyroid structures in creo and want to export it as a step or iges file to work in ANSYS, but if I try to do so, except for the gyroid every other part is getting exported. Is there a solution to this problem. Also I can export it as a STL file which turns out to be heavy, which is not feasible to work with.
Hi @SM_11073988
Have I tried the new option added in Creo 10 to export model to Ansys Mechanical Format?
Export Model to Ansys Mechanical Format (ptc.com)
do they have this option in creo parametric as well? because I am using creo parametric and I want to do CFD on the model in ansys
Why would you want to export the simulation to ANSYS when it could be done in Creo parametric?
Running Fluid Simulation Studies—Creo Simulation Live (ptc.com)
