3-Newcomer
Exporting PDF
Why does it take time to export PDF on Creo, i would like to know if there are other ways around this
How are you creating the PDF? There are 2 methods, print and SaveAs.
How big is your drawing that you need to convert?
How many sheets?
Time is relative and all of the above will impact it.
wittylee3-NewcomerAuthor
3-Newcomer
save as, pdf and selecting file directory,
A0 sheet, i would say fairly large,
4 sheets
StephenW
If the model is complicated and especially if you have 3d -views (lots of lines), it does take a little bit to create. They tend to be large PDF files also.
You should try the print to PDF if you have a PDF printer driver (I think windows now includes it) to see if it improve the time.
Also, if you are printing to a large paper size, that does increase time (in my experience) due to the larger size of the PDF.
I would suggest experiementing with different settings to see if you can find a reasonable compromise between time and quality
also if the drawing contains lot of text and you stroke text fonts, then you will get extremely large PDF.
