External parameters in assembly
Hi all
is it possible to link parameters to a notebook or excel in assemblies?
For example i would like to control the angles in this system of linkages (see picture) by changing values in a table.
tbraxton
tbraxtonAnswer
Yes, layouts can be declared to assemblies and skeleton models. The main function of Notebooks is to define global parameters and then propagate them in a top down design. The example I posted above is used to drive multiple internal combustion engine architectures that employ skeletons, assemblies, and mechanism definitions.
With the notebook in session, open a part or assembly.
For a part, click Model Intent ▶ Image Declare. For a part or an assembly, click File ▶ Manage File ▶ Image Declare. The DECLARE menu appears.
Click Declare Nbk. A menu with a list of notebooks active in the current session appears.
Select the name of the notebook to which you want to declare the model. The model now references the notebook
i am using creo 4.0 commercial license
Hi CreoCarlos,
You could try from excel from here:
Turns out excel analysis is quite a good tool for a lot of stuff, thank you !
tbraxton
You can use a Creo Notebook (.lay) file to manage the definition and propagation of parameters to models. You can declare and undeclare the layout to a given model to enable or disable the functionality. Tables are supported in Notebook files.
This is an example of a Notebook used to control multiple parts and assemblies from a table.
Notebook with a tableNotebook with a table
Yes but this only works for components doesn´t it?
I can´t declare a notebook to an assembly and thus i can´t control its positoning nor is it possible to declare it to a motion skeleton.
You can also create a drawing in Creo, build a table and add the parameters into the table to control the angles.
Does this work with assemblies aswell? I know it works to control components but can you control positions in assemblies?
Hi CreoCarlos,
With excel it works fine, with these 2 cells I control angles:
I changed the values, and regenerated the assembly:
