Jul 19, 2013 10:52 AM UTC
Extract numbers from string in creo
Have parameter that is 914klm5ft12or3467 that is a string
i want to filter numbers and put in a parameter that is REAL like 9145123467
Any suggestions?
Jul 29, 2013 9:25 PM UTC
exactly how does the parameter evaluate?
Jul 30, 2013 9:27 AM UTC
this parameter evaluates some extracted values from tables "extract(TABLE_1,1,3)", "extract(TABLE_1,3,6)"
in old files case evaluates the modelname parameter (that is a string) and compose with extracts the "NUMBERCAD" parameter that drivers the numbering in pdm
in othe case i have to extract only numbers to acquire gps coordinates or absolute coordinates (that are comma separated values)
all those things are acquired as strings and shall be filtered and turned in to numbers
Jul 29, 2013 9:28 PM UTC
Are the occurences of numbers in that string random? Is the string's length also random?
Jul 30, 2013 1:09 AM UTC
I can only see this in an extensive -IF- clause that evaluates each entry in the string as a valid "numeric" string that represents a number and next, determine the length of the full number string... and create variables, again based on an extensive -IF- to determine the value of each string"number".
Something like:
(capture every character as a variable)
(evaluate every variable purging alpha characters)
if A=="1"
AN=1
endif
if A=="2"
AN=2
endif
(Determine the string length)...
(multiply each variable by 10,100, 1000, 10000, 100000, etc...)
(add all the variable together)
Would I want to write this? NOPE!
We need a simple function that will parce a value from a text string by purging non-numeric characters.
As for the OP's request, I would reverse the requirements by making the string from the values rather than making the value from the string.
Jul 30, 2013 9:42 AM UTC
NUMBERCAD=rel_model_name
than from this parameter "NUMBERCAD" that is a string (because model_name is a string) try to filter and get only numbers.
in creo relation there in no way to extract FROM a string TO a number, but is only possible to do the opposite with this command "extract(PARAMETER,3,6)" (extract from third value of parameter 3 following values)
also i should reverse the requirements but you can't drive new file name in creo and you can't put filters on creation
2-Explorer
Oct 29, 2016 10:38 PM UTC
I'd base it on something like this:
/*Without comments
digitlist = "0123456789"
value = 0
digit_found = search(digitlist,extract(rel_model_name(),len(rel_model_name)-0,1)-1
value = value+digit_found
digit_found = search(digitlist,extract(rel_model_name(),len(rel_model_name)-1,1)-1
value = value+digit_found*10
digit_found = search(digitlist,extract(rel_model_name(),len(rel_model_name)-2,1)-1
value = value+digit_found*100
digit_found = search(digitlist,extract(rel_model_name(),len(rel_model_name)-3,1)-1
value = value+digit_found*1000
d0=value
This was to clip numbers at the ends of parameters. In your case I would have the logic start with the first one and use
IF digit_found <> 0
value = value*10 + digit_found.
ENDIF
Then wrap the digit_found ... and IF digit_found ... in an
IF len(parameter)> whatever_step
digit_found ...
IF digit_found...
value = ...
ENDIF
ENDIF
Repeat for whatever_step = 1 to whatever the maximum number of characters you expect.
Since it's an integer, ITOS() should work OK if you need a string.
HamsterNL
18-Opal
Oct 24, 2017 9:53 AM UTC
This was exactly what I was looking for. In my case, I wanted to convert the last 3 characters (string) from our part name to a number.
I have shortened the code just a little bit more:
DIGITS = "0123456789"
TEMP = 0
TEMP = TEMP+(SEARCH(DIGITS,EXTRACT(REL_MODEL_NAME,STRING_LENGTH(REL_MODEL_NAME)-0,1))-1)*1
TEMP = TEMP+(SEARCH(DIGITS,EXTRACT(REL_MODEL_NAME,STRING_LENGTH(REL_MODEL_NAME)-1,1))-1)*10
TEMP = TEMP+(SEARCH(DIGITS,EXTRACT(REL_MODEL_NAME,STRING_LENGTH(REL_MODEL_NAME)-2,1))-1)*100
You can extend this for as long as you like.
Just one warning, there is no error checking!
TomU
Oct 24, 2017 1:13 PM UTC
Keep in mind that you're going to get a negative 1 any time this encounters something other than a number (anything not present in DIGITS.)
