3-Newcomer
Extruding a 3D Circular pin
I am trying to extrude a .1250 radius circle and it keeps turning into a hexagon. How can I fix this ?
kdirth
kdirthAnswer
My best guess is that edge display quality is set to low, affecting how accurately the model is displayed (it is still round).
Go to File > Options, select Enitiy Display and change Edge display quality to a higher level.  This may affect the performance of the program, requiring more computing power to render the model.
tbraxton
Not enough information provided. Post models or explain in detail what you are having an issue with.
kdirth
kdirth21-Topaz IAnswer
3-Newcomer
That worked, thank you so much!
