Failed Annotation Hidden From Model Tree
Having inherited a model, I have discovered a failed annotation which I am struggling to resolve.
Creo flags a GTOL (gp9), as failed (for unknown reasons). This failed annotation doesn't show up in the annotation list, nor any of the sub-component annotation lists.
From the notification centre, I can right click - Edit Annotation or Locate In Model Tree. Neither of these functions seem to do anything. The edit opens up the Geometric Tolerance feature but I cannot make any changes. Locate in Model Tree also doesn't show where it is located in the model tree.
Where is this hiding and how do I show it/remove it?
Pre-edit: while filling this out, I have discovered that 'Locate In Model Tree - Delete' deletes it and resolves my issue, however doesn't answer the question of where it was being hidden. Does anyone have any idea how one would locate a GTOL that has been hidden from the tree?
Running on Version 8.0.4.0
Article - CS290515
This article may be help you
